Browse Forums DIY, Home Maintenance & Repair 1 Jan 18, 2011 6:29 am Hi all, We've only been in our house for 4 months, and are using tankwater to flush our toilets. Over the past few weeks we've noticed a bad smell coming from the tankwater. DH has cleaned the inlet area on the tank as there were lots of rotting leaves however the smell is still there. Is there anything we can use in the tank to neutralise the smell that won't damage the pump? The tank is full from all the Melbourne rain and the water is used frequently (2 young kids - lots of toilet flushing). Thanks for any advice! Re: Smell from tank water 2Jan 18, 2011 6:57 am This type of environment usually is favourable for the growth of algae inside the tank. I would chuck a few chlorine tablets usually you can get them from your local pool shop. It is something that you need to do from time to time so that it does not happen again. Hopefully, it will help. 18 90360 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10516 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17513 |
