Browse Forums DIY, Home Maintenance & Repair 1 Jan 05, 2011 11:01 pm Hi All, Our external balcony, which is a 125mm 40 year old slab supported on four sides, is experiencing hair line cracks on the underside where pieces of concrete have fallen away revealing rusted mesh (seems NSW tradies have been dojee since the ships came in - mesh is only a few mm away from the lower surface of all 125mm!). I take it calling out the engineer is the way to go with this one? Is there a repair? - I can seal it from above, but is the rust able to be delayed? Has anyone here ever had to replace a concrete balcony? Thanks Steve Re: Hair line cracks and rusted mesh in concrete balcony 2Jan 08, 2011 3:32 pm I think you need to get an expert to have a look at this. Basically the problem is that the steel reinforcement should be about 40mm from the surface. With this depth of concrete the natural alkalinity of the concrete protects the reinforcement from rusting. It might be possible to get the reinforcement blast cleaned and then use sprayed concrete (shotcrete) to build up the depth of concrete on the underside but its not a DIY job. Have you contacted your insurer as it sounds like you could have a claim! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 6516 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11613 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10835 |
