Browse Forums DIY, Home Maintenance & Repair Re: Stuck tap washer (jumper valve) 4Jan 08, 2011 2:53 pm Hi I need to provide an update on this after completing the job. This tap is for the shower and due to the depth of the wall there is a spindle extender. So before I could get at the washer I needed to unscrew another 'extender body housing' (don't know the correct name). Once this came off, I could get at the washer which came out fairly easily, do the reseating, and insert a new washer, then screw in the extra housing, then the spindle together with the spindle extender. Re: Stuck tap washer (jumper valve) 6Jul 27, 2021 1:25 pm Tonymoon Hi boyds I just found your message it is along time ago but are you still contactable. I have the same problem and cannot figure how to remove the 'e tender bidy housing' Thankyou. Hi Tonymoon - did you figure out how to remove the tap extender body? Cheers m8 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6936 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16836 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7349 |
