Browse Forums DIY, Home Maintenance & Repair 1 Nov 06, 2010 6:58 am Hi all, I'm new to this site and not a handyman at all. Our verandah roof if currently leaking after I had replaced some transparent sheeting and replaced them with laserlite a couple of months ago. Where the laserlite sits in the tray at the house end of the verandah, there was some black, porous material. I guess, that had prevented the previous sheet from leaking. Any idea, what that could have been or what I can use to make the leaking stop? It's only dripping, when the rain gets a little harder. I think, because the verandah roof has a fairly low pitch, the wind pushes the rain up against the end of the roof and makes it leak. Any suggestions very welcome. Thanks Re: Verandah roof leaking near house 3Nov 07, 2010 10:57 am You can purchase that foam from the same supplier where the laserlite was purchased. It is sometimes shaped to match the roof profile and it seals those gaps Builders are people too.... Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3377 1 3046 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24228 |
