Browse Forums DIY, Home Maintenance & Repair 1 Nov 03, 2010 8:48 pm I'm hoping someone can help me with an annoying problem. I had a handyman erect a garden shed for me and he laid a slab which is a bit bigger than the actual shed. Now when it rains the rain lands on the bit of extra slab and flows under the walls of the shed inside. Can someone suggest the best way to waterproof the gap between slab and shed? THanks a lot. Re: Water flows into shed between slab and shed walls . 2Nov 03, 2010 8:50 pm Get an angle grinder and angle the concrete away from the shed. Use a caulking gun to seal the shed edges. Re: Water flows into shed between slab and shed walls . 3Nov 03, 2010 9:04 pm Thought of getting the angle grinder and cutting a drainage channel. The slab is actually a foot wider than the shed on one side and about 3 inches on the others. It would take some grinding to angle it away but I guess with perseverence I could on the 3 inch sides. Re: Water flows into shed between slab and shed walls . 4Nov 03, 2010 9:06 pm alternatively you could install some flashing around the perimeter. Re: Water flows into shed between slab and shed walls . 6Nov 04, 2010 9:02 am run a bead of no more gaps or similar around the internal perimeter of the shed and allow 24 - 48 hours for it to cure. Then use a self levelling compound inside the shed floor - looks schmik and covers up the sealant! Water this close to the slab edge or under the slab can cause slab heave or subsidence and is potentially a serious problem especially on highly reactive clay soils. Over… 6 2991 8 3960 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 8028 |
