Browse Forums DIY, Home Maintenance & Repair 1 Nov 03, 2010 9:02 am I have a double fluro light in the kitchen. One of the tubes has got burnt at one end and one of the prongs has got stuck in the slot. My first reaction was to get a screw driver and try to unscrew it out but i'm not sure if that's safe? Or would it require a whole new light fitting? I'm not sure why it happened as the tubes are only a few months old and only get used at night for a short time.
Re: Help: Any electricians here?... problem with light. 3Nov 03, 2010 3:51 pm My advice is to replace the complete fitting-by the time you get the tombstone replaced and find other bits astray inside the fitting, jettison the whole lot and start again. New fitting, another 10 or so years of light out of it. Re: Help: Any electricians here?... problem with light. 4Nov 17, 2010 8:17 pm E1109 My advice is to replace the complete fitting-by the time you get the tombstone replaced and find other bits astray inside the fitting, jettison the whole lot and start again. New fitting, another 10 or so years of light out of it. he's right but before doing things make sure that you have switched off the electricity of the entire area you're working for you not to be electrocuted 2 6039 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 18139 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13042 |
