Browse Forums DIY, Home Maintenance & Repair 1 Oct 27, 2010 7:34 pm Hi There, situation: weatherboard home, 50s, cracked plasterboard. But its not too bad just on some joints. Plus new plasterboard, you look at it, there is a dent. The old boards are just indestructable. Door knob from the front door banged against it, lost its paint. Board still in shape. Would have went straight trough plasterboard. So I want to keep the old boards if possible. My idea is: where they are pushed together and peel from the wall, I just cut a little gap to relief the pressure, scratch a V-gap, sand it smooth where it buckles and fill it all up, paint, done. Any help, ideas, suggestions? Captn Hoek. Re: how to repair fibrous plasterboard 4Oct 29, 2010 8:59 pm Captn Hoek Hi There, situation: weatherboard home, 50s, cracked plasterboard. But its not too bad just on some joints. Plus new plasterboard, you look at it, there is a dent. The old boards are just indestructable. Door knob from the front door banged against it, lost its paint. Board still in shape. Would have went straight trough plasterboard. So I want to keep the old boards if possible. My idea is: where they are pushed together and peel from the wall, I just cut a little gap to relief the pressure, scratch a V-gap, sand it smooth where it buckles and fill it all up, paint, done. Any help, ideas, suggestions? Captn Hoek. yes but you could also replace the damaged portion not too hard to do it and better job by far Re: how to repair fibrous plasterboard 5Oct 29, 2010 9:57 pm then I would have to do the entire wall, patch repair won't work. And, the paper stuff just does not cut it, has more dents after 4 months than the rest after 60 years. Should have put FC sheet next to the manhole, no idea how long that new bard is going to last my ladder leaning agaunst it. Re: how to repair fibrous plasterboard 6Nov 29, 2010 9:33 pm You actually were spot on with your own suggestion. Scrape the loose paint away, cut a V along the crack, Nail on each side of the crack wherever their is timber, Plaster, sand then re paint. And don't forget to put a doorstop to stop the same thing from happening Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7898 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2550 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 3012 |
