Browse Forums DIY, Home Maintenance & Repair 1 Sep 29, 2010 6:34 am Hi Everyone, The exterior of our house (once the extension is finished) will be blue board which we will then paint with a "render-looking" paint. I can't for the life of me remember the names of the brands but hopefully some of you will know what I am talking about. To save costs we will be painting the house and I was wondering if any of you have used this type of paint before and whether there is anything we should be aware of (pitfalls etc). I am assuming we would have to prime the surface, but is there anything else? Cheers! Micklou Re: "Render" paint and blueboard 2Sep 29, 2010 8:55 am I know dulux have a render paint. We were looking at using it for an internal brick wall in our place but it would have been too costly. So we decided to render the wall ourselves and paint it. Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: "Render" paint and blueboard 3Sep 29, 2010 5:07 pm check out ' http://www.dulux.com.au/specifier/produ ... e-finishes ' for the dulux stuff. im sure the other companys would have similar products. it will be quite expensive because you use a lot of it. roll very slowly to avoid it spraying everywhere, because you can easily end up with more on the ground than on the wall..lol it wont hide as much as you would expect.. un sanded patches, dents etc, will still be visable. most of the roll on products can be treated as really thick paint. Re: "Render" paint and blueboard 4Sep 30, 2010 7:39 am Taubmans have ARMAWALLbut it really is not a DIY product I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: "Render" paint and blueboard 5Oct 03, 2010 7:44 am Thanks for the replies. It is such an important job - we need to get it right. Cheers! Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18072 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7964 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6913 |
