Browse Forums DIY, Home Maintenance & Repair 1 Sep 27, 2010 10:15 pm Hi The reticulation system in my garden has developed a snag and I was hoping someone can shed some light on how to fix it. My dog chewed off the solenoid a few weeks back and I ended up replacing the solenoid. Now the problem is that Station 1 is running with every other station. To elaborate, Station 1 runs first,then when it's Station 2's turn 1& 2 run together and then 1 & 3 and so on. Obviously because of this all other stations except 1 run with reduced pressure. I have checked the wiring and it appears to be wired the way it was earlier. Any help or tips would be highly appreciated. Thanks Sid Re: Problem with Reticulation system 2Sep 29, 2010 1:12 am Take the valve apart and clean the whole thing. Dig away the soil so water won't re enter the valve body and put sand in. You don't need to remove it, just take the top apart and leave the body connected to the system. Make sure the solenoid on the top of the valve body is screwed in correctly. Also check the bleed screw or manual operation "thingo" isn't open and letting air through. If there is air getting in, it opens the valve when water pressure appears 2 5860 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 17943 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 |
