Calculating the mass of materials was never my strong point....
If I have approx 7sqm of floor, how do I calculate the amount of concrete required to lay a 40mm topping on the floor? I have to purchase sand and cement for this.
can anyone help?
Browse Forums DIY, Home Maintenance & Repair 1 Sep 18, 2010 8:28 am Calculating the mass of materials was never my strong point.... If I have approx 7sqm of floor, how do I calculate the amount of concrete required to lay a 40mm topping on the floor? I have to purchase sand and cement for this. can anyone help? Re: Estimating amount of concrete 4Sep 19, 2010 10:38 am Hi Camelia, I cubic metre of concrete weighs 2.4 tonnes. 1 cubic metre = 6 x 50kg bags cement and around 1.76 tonnes ballast (sand & pebbles) & water makes up about 400kgs or litres. So if you need 0.28 m3 of finished concrete, you will need 84kgs cement (not quite 2 x 50kg bags) + 493kgs of ballast (not quite 1/3 m3). You should end up with a very small amount left over... Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Estimating amount of concrete 5Sep 19, 2010 10:44 am Bags of cement are in 20 kg lots. There are mini mixers(trucks) that mix on site ...and saves a LOT of backs. Where you are coming from is where you are going to... Re: Estimating amount of concrete 7Sep 19, 2010 11:13 am 40 kg bags are not allowed anymore OH&S Where you are coming from is where you are going to... 10 3781 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9862 |
