Browse Forums DIY, Home Maintenance & Repair 1 Sep 17, 2010 8:11 pm We have selected to have a flush finish to our Mortar as per what we found on a display home. Our builder has called and suggested that a rolled finish creates a stronger joint and that flushed mortar is prone to chipping but is leaving the decision with us. Our bricky starts on Monday Has anyone come across this before and what was your experiences Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7012 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18134 |
