Browse Forums DIY, Home Maintenance & Repair 1 Sep 05, 2010 8:03 pm Has anyone got any ideas on how to renovate these ornate cornice's I found behind the suspended ceiling in my brisbane post war home? The pics should be at the URL below http://s924.photobucket.com/albums/ad89 ... c/Cornice/ Re: Ornate Cornice Renovation 2Sep 06, 2010 12:26 am when you say renovate what do you mean?? are you are wanting to keep them or are they damaged and need repair?? If they need repair get a professional plaster reproductionist in they will sort it out for you I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Ornate Cornice Renovation 3Sep 06, 2010 7:47 am I want to keep the cornice. I guess restore is a better word. At the moment they are covered in layers of paint. How do I remove the paint, as sanding will be difficult? A professional plaster reproductionist sounds expensive, can you recommend any experts in Brisbane. Re: Ornate Cornice Renovation 4Sep 06, 2010 9:36 pm no sorry I have ornate ceilings in the bedrooms and they are beautiful but really its a job for a pro unfortunately I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Ornate Cornice Renovation 5Sep 07, 2010 2:54 am From your pics they mostly need a good clean and a lot of caulking plus a repaint. Wash them down with sugar soap, then get a paint scraper and scrape anything loose away from the cracks. Wipe down any dust and caulk the cracks along the cornices with a flexible sealant like selleys no more gaps, use a plaster patching compound to fill any wall or ceiling damage or cracks - with the patching compound you need to slighly over fill and then sand it back flush once it's set, and paint with a good primer and two top coats. I've done the same in my house (some of your cornices are actually the same as mine), it's quite a bit of work but it will come up really nice once it's done. It's all just caused by movement over the years but it's just a cosmetic fix up. Re: Ornate Cornice Renovation 7Sep 07, 2010 9:08 pm piscean From your pics they mostly need a good clean and a lot of caulking plus a repaint. Wash them down with sugar soap, then get a paint scraper and scrape anything loose away from the cracks. Wipe down any dust and caulk the cracks along the cornices with a flexible sealant like selleys no more gaps, use a plaster patching compound to fill any wall or ceiling damage or cracks - with the patching compound you need to slighly over fill and then sand it back flush once it's set, and paint with a good primer and two top coats. I've done the same in my house (some of your cornices are actually the same as mine), it's quite a bit of work but it will come up really nice once it's done. It's all just caused by movement over the years but it's just a cosmetic fix up. Ditto all this. I find the cornice itself doesn't need much sanding, it's more the cracks on either side between wall and ceiling. I've used a soft toothbrush to clean in the nooks and crannies, it's a bit laborious but cleans out all the dust and loose particles. Good luck and don't forget to post photos. What a find, they are absolutely beautiful and worth putting in the time and effort. The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 8492 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5465 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3482 |
