Browse Forums DIY, Home Maintenance & Repair Re: 155mm kauri pine board 7Sep 14, 2010 6:28 pm Danmar Minyak (also known as Malaysian Kauri Pine) is often used in place of Australian Kauri Re: 155mm kauri pine board 8Sep 14, 2010 10:10 pm thanks duke...I have a few lengths of the minyak...it isn't quite the same...it's 20mm (old kauri 22mm) thick and still only 150mm wide. It also is a bit lighter in colour and doesn't quite match the other boards. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52856 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 |
