Browse Forums DIY, Home Maintenance & Repair Re: Stormwater drain 3Aug 26, 2010 12:59 am It looks like it only 32mm pipe coming from the gutters? If not maybe 50mm, either way it is pretty small. The PVC pip is pretty easy to cut and repair. Cheap to. I'd be looking to see if that isn't what was blocked before you call in to fix the pipe in the ground. Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7931 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4534 |
