Browse Forums DIY, Home Maintenance & Repair 1 Aug 14, 2010 4:59 pm Does any one have experience of overpainting a colorbond roof? I live in SE Qld and have a 13 year old white colorbond roof. The paint has gone a bit chalky and easily grows mould so we have decided to get it repainted and our preferred colourscheme has colorbond ironstone for the roof. Can anyone tell me if having a dark roof makes any noticeable difference to temperature within the house? Also for the overpainting does a coat of metal primer and 2 coats of a reputable brand of acrylic roof paint or roof membrane have a good result for up to 10 years? Are there likely to be problems with patchy fading or paint cracking or flaking? Are there any better products than acrylic paint? Sally K Re: Colorbond roof overpainting 2Aug 15, 2010 7:29 am Yes. But before you do, clean the surface. This can be done using a mop or soft bristle brush with non-ionic detergent (such as kitchen detergent) and water. The surface should then be hosed down thoroughly with water and allowed to dry the second rinse removes any detergent residue and is as important as the clean suface Colourbond is just a painted metal surface no need for primer Painting over the colourbond expect to do more than 2 coats as you will be going over white and ironstone is fairly dark possibly 4 coats or more Acrylic is best as it will expand and contract with the colourbond 10 years possible yeah possibly Just use a high performance exterior paint - Dulux weathershield, Taubmans Endure, Wattyl Solagard If the steel is being used to catch drinking water, also check with the manufacturer that the paint is suitable for this purpose. It's important to note that overpainting COLORBOND® steel will void any warranties issued by BlueScope I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Colorbond roof overpainting 3Aug 28, 2011 7:32 pm Sally K Does any one have experience of overpainting a colorbond roof? I live in SE Qld and have a 13 year old white colorbond roof. The paint has gone a bit chalky and easily grows mould so we have decided to get it repainted and our preferred colourscheme has colorbond ironstone for the roof. Can anyone tell me if having a dark roof makes any noticeable difference to temperature within the house? Also for the overpainting does a coat of metal primer and 2 coats of a reputable brand of acrylic roof paint or roof membrane have a good result for up to 10 years? Are there likely to be problems with patchy fading or paint cracking or flaking? Are there any better products than acrylic paint? Sally K Hi Sally, yes i have been overpainting Colorbond Roofing in Australia since - 1988 for Bluescope steel Limited. Terry Group is the preferred contractor for Bluescope Steel Limited. Sally the information that you have stated reveals that your roof is in need of overpainting. ( chalky ) Patches? Ironstone is a deep colour as is Woodland Gray, both classical heritage listed colours. Dark colours generally draw and obsorb the heat of the day(sunlight) The 549 line is the existing paint finish that is on your roof presently. The 549 line as it is known is used of the paint line in Port Kembla, N.S.W. where the Colorbond Roofing Sheets are made. No a metal primer is not used on the Colourbond Roofing ( overpainting)only for the re -painting of the Zincalume Roofing. No Acrylic paint systems are to be avoided on a previousley painted Colorbond Roofing. Incompatiable paint systems. ( chemical reaction) The reason being the existing 549 line is a thinners based product. ( Dulon Thinners ) If an acrylic paint system (water based) is placed ( spray painted) onto a Colorbond Roof, the acrylic paint is not compatiable with the existing painted finish. The Acrylic paint will soon show signs of cracking known in the trade as crockadiling. Then patches will begin to appear. Membrane coatings are known to reflect the harmfiul rays of the sun,and keep your home cooler in summer. (noxyide ) Their is a 10 year guarantee / warranty on all Bluescope Steel Roofing Products. The only successful way to prepare and overpaint Colorbond Roofing is to clean down the roof area using industrial mops, and brooms (patio brooms) with the use of Prepsol (industrial cleaner) acknowledged by Bluescope Steel Limited, pressure washing to 4000 psi (maximum ) Then apply two coats of the 549 line by spray application. Their are a number of technical procedures to follow in order for success to be achieved. Their for it is recomended that an accredited applicator be used for this type of specialised work. Sally you and anyone having some trouble with your Colorbond Roofing in Australia are welcome to contact me for both technical and trade advice. Terry Group is the prefered contractor for Bluescope Steel Limited. A registered and experienced applicator of the 549 line onto a correctly prepared substrate ( Colorbond Roofing) Sally please email me on - radhaterry@yahoo.com.au for any concerns about your Colorbond Roof. I do hope this meets with your approval and i assure you of my best intentions. Kindest regards from Michael Terry Heritage Consultant Roofing Terry Group Mobile no - 0439110153 Re: Colorbond roof overpainting 4Aug 29, 2011 4:29 am Sally, I used to be a fastidious industrial floor coating applicator and I even painted floors at the Hastings (Victoria) steel mill where they made colorbond too, and I would just like to say that disreputable painters do not give good advice like Michael Terry has done in the above post. Michael sounds like a true professional to me. Before I became a floor coating applicator I used to remove graffiti from buildings in the 1980's and I found colorbond to be the best paint system hands down because I frequently removed graffiti from it using paint strippers without damaging (much) the colorbond underneath. My guess is that it is worth painting again the correct way. Re: Colorbond roof overpainting 6Dec 18, 2013 9:29 am The previous posts in this thread seem to be out of date. Water based acrylic is recommended by Bluescope. http://steelproducts.bluescopesteel.com.au/files/dmfile/TB2NextGenSept2013.pdf Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10347 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 19423 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2991 |
