Browse Forums DIY, Home Maintenance & Repair Re: Dorf Venus Kitchen Tap - replacing washers? 2Aug 06, 2010 4:29 pm taps need to be re-seated once you replace a washer. only a licensed plumber should be doing it. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: Dorf Venus Kitchen Tap - replacing washers? 3Aug 08, 2010 6:08 pm Venus taps need the whole cartridge replaced, they don't have your normal washer as they are ceramic disc and from anything I've had to do with them, they don't do just the ceramic disc kits. If you can get the handle off, its not that hard to change the spindle, you just need the right sized spanner/wrench to get the spindle (cartridge) out and put the new one in. Remember to turn your water off first. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7379 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6714 7 5137 |
