Browse Forums DIY, Home Maintenance & Repair Re: Fixing chips in render 6May 29, 2010 7:30 am Get a bag of acrylic render (easier to apply and finish), trowel on leave a while then depending on required finish, sponge smooth. Don't use brickies sand if you want to use sand and cement use washed sand Landscape Design & Construction http://cherub.squarespace.com/ I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4857 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8964 |
