Browse Forums DIY, Home Maintenance & Repair 1 May 18, 2010 11:26 am I want to renovate my laundry but the ceiling is asbestos (about 5sqm) I want to have it removed but the carpenter said he would just gyprock over it. I don't like this idea. Does anyone know approximate costs of removal? can it be done safely and how and where can it be disposed of? Are there builders who would do the removal/disposal and renovation together? Re: Renovate laundry with asbestos ceiling 2May 18, 2010 12:33 pm With all that has been in the media regarding asbestos, one question comes to mind... does your carpenter know what he's dealing with? There are companies who specialise in asbestos removal. These guys look like spacemen with their safety gear! IMHO I'd be getting someone in to remove all the asbestos you have before doing too much else Oceanic with Nautilus upgrades. Handover 8 September 2010 Re: Renovate laundry with asbestos ceiling 4May 21, 2010 11:45 am Camelia, I'm surprised noone else (tradies in particular, or those with industry experience?) have replied to your post. As I mentioned, I really know diddlysquat about asbestos, but know that it's not to be messed with. THere are companies who specialise in the removal, and from what I know, I think there are very strict disposal rules set by councils/government. I'd strongly suggest searching the yellow pages for 'asbestos removalists' in and around your area and get some advice and (free) quotes from them. Good luck Oceanic with Nautilus upgrades. Handover 8 September 2010 Re: Renovate laundry with asbestos ceiling 5May 22, 2010 3:38 pm When the asbestos is removed I want the renovation to start straight away...because I have to move out of the bedroom next to the laundry and clear everything out of the laundry (including washing machine) it will be a major disruption...It is much easier to coordninate this project with a builder willing to manage it in it's entirety... Re: Renovate laundry with asbestos ceiling 6May 22, 2010 5:44 pm removing asbestos isnt a carpenters job and probably not something they are interested in doing. Contact an asbestos removal company to do it and then get a plasterer in to install gyprock. Just have a timetable booked so that the plasterer comes in soon after they remove it. You can always use a laundromat or do some washing at a friends house etc. if you need to but having a small ceiling installed after the asbestos is out will be a quick job. Re: Renovate laundry with asbestos ceiling 7May 22, 2010 8:18 pm It is the dust/fibres from asbestos that is dangerous so as long as it is not crumbling and you do not drill it, no problems. We have asbestos ceilings and walls in a few places. No reason not to put the gyprock over the asbestos - seals away the problem and means no removal and disposal costs. Personally, I would leave it in place Re: Renovate laundry with asbestos ceiling 8May 22, 2010 9:11 pm I will need an access panel in the ceiling as an ingress for electrical work, ceiling inspections and any other need to access the ceiling space...I don't want to be crawling through an asbestos ceiling and neither do tradies, etc. I am aware that some builders are licenced to remove small amounts of asbestos but it's hard to locate them therefore I may need to hire an asbestos removalist. At this stage, I am trying to get as much advice and as many ideas as possible. Also, the carpenter didn't want to set the joins on the gyprock....so I think getting a builder is the best option, as they generally do these jobs as well as timber flooring, concreting and wall removals. Re: Renovate laundry with asbestos ceiling 9May 22, 2010 9:46 pm camelia I will need an access panel in the ceiling as an ingress for electrical work. Also, the carpenter didn't want to set the joins on the gyprock.... no this all work for the plasterer to do, installing the gyprock, and access panel and doing the joins on the gyprock. There's no point getting a carpenter in do to any of it and best to get a plasterer who will do all of those tasks. you could either get a builder in to manage the project or organise the tradies yourself but get the right tradies for the different tasks. It's what a builder will do anyway Re: Renovate laundry with asbestos ceiling 10May 23, 2010 11:32 am I don't like the idea of a cast of thousands for a laundry reno....if the builder is worth his salt then he will know who are the right tradies for the job. When you start introducing people from unknown sources then it could be a problem. Re: Renovate laundry with asbestos ceiling 11May 23, 2010 1:30 pm Hello, The problems that arise from sheeting over existing fibro is if you wish to install more lights, a new fan, an access panel etc the fibro will need to be cut or drilled and this will lead to contaminating the area. Firstly you should get the ceiling removed by a licensed asbestos removalist (even though you do not require a license to remove under 10 square meters of asbestos). For a laundry ceiling you would be looking at $800 to $1200.00. Secondly your builder does not want to set the joins, so he might as well not do the job, and you can get a gyprocker to sheet the ceiling and set the joins. Cheers. Shawn Re: Renovate laundry with asbestos ceiling 12May 24, 2010 3:39 pm Thanks for reply (SCA) and all, I'd like to have the asbestos removed....I can see why some people try to cover it (expense of removal) but as you say prevents further drilling etc. I agree if carpenter doesn't want to set the joins he might as well not do the job. where are the builders? Re: Renovate laundry with asbestos ceiling 15May 13, 2012 8:54 pm I wonder where you got this 'carpenter' from as most tradies pass asbestos removal onto Licenced asbestos removalists straight away. 'Setting' gyprock joins (flushing) and I assume that will include cornice replacement too, is not rocket science and I think your carpenter has not been in the industry long enough to pick up other skills to do a small job like this, making him a liability. Arfur Re: Renovate laundry with asbestos ceiling 16Oct 11, 2012 10:37 pm In my old house, the ceiling of toilet, laundry, front door porch are made of asbestos cement sheet. I asked the builder to replace them with plasterboard as part of thew house. aucklandlawnmowing Re: Renovate laundry with asbestos ceiling 17Oct 17, 2012 3:06 am Asbestos is regarded as carcinogenic to the lungs when a person is exposed to its for a longer period of time, It is mined and revealed as a stone made up of small fibers. And in some asbestos removal, Asbestos metal abrasives Re: Renovate laundry with asbestos ceiling 18Feb 01, 2013 11:15 pm If you suspect that asbestos is in your home, or on your property do not touch it or remove it. Call Access Asbestos Removal for all your asbestos removal needs we are licensed, insured and have over 10 years experience in the safe removal of asbestos across all Sydney areas. Re: Renovate laundry with asbestos ceiling 19Mar 04, 2013 7:51 pm We had it done in Australia... Should cost about $55 per hour, that's what we paid to demolish an asbestos shed in the backyard. All safe, and very nice service too. I would definitely have it removed. Does the rest of the house have asbestos ceilings too? We got the back shed demolished (about 9 large sheets of asbestos for $600 or so). If access is easy (should be with the ceiling, it shouldn't cost more than $200 or $300. Do you have photos you can post? the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12046 if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere… 1 13846 What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7317 |
