Browse Forums DIY, Home Maintenance & Repair 1 May 13, 2010 9:18 am Hi all, have a problem with my toilet (had it for a while now). A lot of the times when you flush, the cistern does not refill with water. So you have to take off the top of the cistern and shake the arm that holds the float. Then it starts to refill. I thought something might be blocking it so cleaned with an old toothbrush, but still does it. How do I fix it or do I have to buy a whole new float? I read somewhere there are hundreds of different types so it may not be easy finding the same one. Help is appreciated. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: HELP - toilet won't refill 2May 13, 2010 9:30 am Last year I had similar problems and it was just as easy to replace the whole valve unit...my local hardware store had a universal one that only cost $19.95, when new seals and O rings etc were going to cost more than that. They are physically smaller and much quieter too. Can't remember the brand but something along the lines of 'Universal' and came in a yellow box, think it had green text. Hope this helps? Re: HELP - toilet won't refill 3May 13, 2010 10:04 pm Hey HappyCamper. Went to Reese today and got a whole new valve unit. Hopefully it will do the trick. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7078 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4798 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 24081 |
