Browse Forums DIY, Home Maintenance & Repair 1 Apr 18, 2010 9:12 pm Hi all Our main bathroom has yukky wood panelling around the bath and up the bath wall. It looks pretty bad, with the wood getting on age-wise and it is marked and worn (patchy) in places. As a short-term fix, before we gut the bathroom and start again with tiles, we thought we'd repaint the panels to improve the look a bit. I'd very much appreciate advice on a good product to use - waterproof paint or lacquer? Are there any particular tricks to doing this? cheers! Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9112 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6042 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8337 |
