Browse Forums DIY, Home Maintenance & Repair 1 Feb 15, 2010 4:34 pm Does anyone know if there is a masonry adhesive that will glue gyprock to bricks and is impervious to moisture? Something that you can mix in large dollops? Generally, cement based masonry adhesive is porous to moisture so I'm thinking maybe something with a urethane/polymer base? Re: looking for waterproof masonry adhesive 2Feb 17, 2010 6:05 am Would recommend that you waterproof wall first, as moisture will get into plasterboard wether glue is impervious or not. Landscape Design & Construction http://cherub.squarespace.com/ I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6514 Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old… 0 8088 Hi team, Im looking for a second hand sd4b monitor preferably white. 0 8923 |
