Browse Forums DIY, Home Maintenance & Repair Re: Removing Streaks in Stainless Steel 2Feb 09, 2010 11:36 am Hi Evel, This will probably sound really silly, but olive oil works - my Aunty swears by it and Ive seen her use it. Apply a little to cloth - rub in and buff away, looks brand new Re: Removing Streaks in Stainless Steel 3Feb 09, 2010 12:52 pm mckelvie Hi Evel, This will probably sound really silly, but olive oil works - my Aunty swears by it and Ive seen her use it. Apply a little to cloth - rub in and buff away, looks brand new Not silly at all. Thanks for the tip. I will give it a go. Re: Removing Streaks in Stainless Steel 4Feb 09, 2010 6:32 pm The sparky who installed our last oven said to use WD40. A light spray onto a cloth & wipe it over. He reckoned it is the same as the commercial ss cleaners - I never got around to trying it though sorry. Cheers Kim Re: Removing Streaks in Stainless Steel 5Feb 09, 2010 7:17 pm I use spray n wipe with a chux cloth and then immediately wipe with a dry microfibre cloth 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Removing Streaks in Stainless Steel 8Feb 10, 2010 8:18 pm Yup, pretty much any old oil works. I use an oil-based SS cleaner, like suh, but olive oil is fine. WD-40 is a bit smelly, but if you don't mind that, go for it. I do the stove every couple of weeks (in between, soapy water and drying well works fine), same with the dishwasher front panel. I'm also about to re-oil our outdoor light fittings. You'll find this at the supermarket: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you use too much and end up with a greasy film everywhere, just wipe over with paper towel. Re: Removing Streaks in Stainless Steel 9Feb 13, 2010 4:38 pm Nitric Acid instantly removes staining from stainless steel . But , since 9/11 it's a prohibited item . Some smaller hardware stores still stock it however . Using Nitric on an investment house I had in Harvey Bay I was able to remove some god aweful brown stain on a kitchen sink that resisted all other stuff . Took less that a minute to be effective . Re: Removing Streaks in Stainless Steel 11Feb 15, 2010 10:44 pm As a grommet I worked at place that had heaps of stainless. We used to spray on baby oil then buff back with a paper towel. Perfection Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6809 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14583 6 11299 |
