Browse Forums DIY, Home Maintenance & Repair 1 Feb 08, 2010 10:35 am My interior walls consist of the crumbly render that was so common in the victorian federation era. It's a composition of lime, and so the very fine dust with not very good adhesion. Anyway I have a few cracks and cannot, for the life of me remember what is best to repair my cracks with. Also I have an issue with one of the larger cracks being previously repaired with a rubber type of product ie no more gaps So how can I repair that horrible part without destroying the wall further? Any brilliant ideas? TIA People make one happy, not houses? I do not think so. Houses are more to be trusted than people. Elizabeth Aston, Mr. Darcy's Daughters http://www.youtube.com/watch?v=pmDX0tgONFs http://lightndreamy.blogspot.com/ Re: Repairing cracked walls in an older house. Help please... 2Feb 12, 2010 11:19 am I have this old render in my home and I decided to re-render with cement. It is just too difficult to repair. I think you need something flexible like an acrylic sealant...Sikaflex perhaps? Re: Repairing cracked walls in an older house. Help please... 3Feb 13, 2010 4:34 pm I had a similar issue with a house I Reno'ed last year . I ended up using a masonry drill bit and drilling into the sections were the render kept falling out of . I would drill 5/16ths holes , bend up a bit of steel rod so that the flat part of the "L" was about 3mm below the line of the wall and use liquid nails to fit them. I spaced the rods every 100mm and rendered the whole lot in when I was finished . I wet the area before rendering as that helps bind the new to the old . Using this method I was able to repair about 2 square meters of wall that had render crumble out of . In my case I tried 6 attempts with everything else I used falling out . With the house final settlement in 2 weeks you can see a little crack starting to appear on the edge of one of the areas and thats not bad as I did the last repair 4 months ago . I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36937 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4859 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8911 |
