Browse Forums DIY, Home Maintenance & Repair Re: Help - my roof is leaking 2Feb 05, 2010 2:37 pm camelia My tiled roof is leaking onto the gyprock ceiling. What can I do to fix it? I'm worried it may collapse Well, first ascertain whose responsibility it is. EG is the roof under any sort of warranty as in a new home? Regardless of whose responsibility, the questions that need answering are - Where is it leaking? Why is it leaking? A good start to answering both questions would be to spend some time in the roof-space when it is raining or when someone is spraying the roof with a hose. The actual leak can be many metres from the wet ceiling area as the water can travel on just about any structure in the roof-space. Then again, maybe the defect causing the leak will be obvious from the outside with a careful roof inspection. Sorry, the question is a bit vague to allow much more comment or be more helpful.... Cheers zeke Re: Help - my roof is leaking 3Feb 05, 2010 3:14 pm I had to inspect a leak in the roof recently, damaged plaster to bathroom ceiling. Typical dry day on inspection day so went in roof space over affected area. Identified a leaking plumbing fitting was the cause. Nothing to do with the roof at all. All options should be investigated thoroughly as first impression as to cause may not infact be correct. Good luck Re: Help - my roof is leaking 4Feb 05, 2010 3:17 pm that is a fact DD Where you are coming from is where you are going to... Re: Help - my roof is leaking 5Feb 06, 2010 10:16 am Thanks zeke and dirk, there's no warranty, its and old house (although the gyprock ceiling was replaced 2 years ago). I can see several places around one end of the house where water is dripping in during the rain. It is also leaking around the ridge capping on one of the hips. Some of the tiles have cracks and some have moved apart. whenever anyone walks on the roof ( it is very steep) some tiles crack..due to their brittleness. some of the battens have also sagged. Re: Help - my roof is leaking 6Feb 06, 2010 10:22 am Oh well then that bring you back to the beginning. So you need help or want advice? Where you are coming from is where you are going to... Re: Help - my roof is leaking 8Feb 06, 2010 10:40 am Hmm yes not cheap but might be a better option Where you are coming from is where you are going to... Re: Help - my roof is leaking 10Feb 06, 2010 10:48 am What roof area do you have? Where you are coming from is where you are going to... Re: Help - my roof is leaking 12Feb 06, 2010 11:05 am Yeh but then you have eaves, verandahs, hips and valleys. Like I said not my field (tiles) but I know tin is about $10 sq mtr plus labour about the same :ducksforcover: before the roofies kick me Where you are coming from is where you are going to... Re: Help - my roof is leaking 14Feb 06, 2010 11:11 am hey I GTG Maybe someone else will pop up with something clearer. Night, Onc PS Hope that was helpful to a degree Where you are coming from is where you are going to... Re: Help - my roof is leaking 15Feb 06, 2010 6:04 pm Hi, which city are you in? I know in Sydney that colorbond roofs are about $70m2 for supply and fix. Re: Help - my roof is leaking 17Feb 06, 2010 7:27 pm About $50sqm for a terra cotta tiled roof and$40m2 for a concrete roof tiler. You laso have to allow about $1,000 to remove and tip the existing roof tiles. Re: Help - my roof is leaking 19Feb 07, 2010 11:01 am One roof leak, doesnt necessarily mean that you need a new roof. You may only have one or a few tiles that are cracked and broken and can easily be replaced. Same with the ridgecapping, It doesnt take much to repoint it. You could spend a couple of hundred repairing it or thousands replacing it. Re: Help - my roof is leaking 20Feb 07, 2010 11:18 am Hi VVS, I see your point...I have been thinking about it all weekend and of course I dont want to spend thousands if I can get away with less. There are many factors in the decision. 1. The tiles are original (about 1918) On the underneath of them is a kind of lichen or mold (it is powdery) and the tiles are damp on the underside (you can feel it and see it). 2. There is no sarking.3.The tile battens are sagging and there a places where the hardwood supports feel damp and are getting a bit soft. Repairing the roof would be OK for a while but how long before the problems come back? I'm just worried that when anyone tries to walk on the roof the tiles are cracking. I dont have enough $ for a new roof so maybe I will just have to wait until I do and just hope it holds up long enough. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 2 9448 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 |
