Did you see the PM I sent you?
The walls do not extend above the roof. They are just normal walls. Maybe a few pictures could help out here.
Sorry, what is a PM?
Browse Forums DIY, Home Maintenance & Repair Re: Touch up paint required for colorbond roof 22Jan 20, 2010 10:54 am Look in the top right hand corner see it will say you have 1 new message Where you are coming from is where you are going to... Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3073 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2128 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10209 |
