Browse Forums DIY, Home Maintenance & Repair 1 Jan 16, 2010 8:31 pm Hi everyone. I had a quick question about rendering a home. Can render be applied over the cement sheet infills used above windows and if so, is it much more expensive than rendering directly on to brick? Also, can render be applied to a timber beam used above a garage door? Our covenant specifies that we must render the home (including sides) and I was hoping to find out if I needed to upgrade from cement sheet infills and a timber beam above the garage door before render can be applied, or whether they can be left as is and save me some cash. Any help would be appreciated! Re: Rendering home, questions... 2Jan 16, 2010 8:41 pm Are the cement sheets Blueboard? Theres no problem rendering over them, The timber beam would need to be sheeted as well. Re: Rendering home, questions... 4Jan 16, 2010 9:00 pm If its Blueboard it will be blue Most other fibre cement sheeting is grey. You wouldn't paint it no, it would be rendered with a product such as Granosite Re: Rendering home, questions... 5Jan 16, 2010 10:08 pm Can I ask another quick question. If the cement sheet is not flush with the brickwork but recessed, is there some way it can be filled so that when both the brickwork and the cement sheet are rendered it creates a flat surface? Re: Rendering home, questions... 6Jan 17, 2010 9:54 pm It would depend on the difference but at a guess no. You use different rendering techniques and materials on the two surfaces anyway. Re: Rendering home, questions... 8Sep 14, 2010 9:34 pm twisti Can I ask another quick question. If the cement sheet is not flush with the brickwork but recessed, is there some way it can be filled so that when both the brickwork and the cement sheet are rendered it creates a flat surface? In my life a I have done lots of rendering so yes there is a coarse layer and a fine layer of render applied, after the coarse one has gone let it dry and then apply the fine layer in in that way you'll achieve a flush render. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 |
