Browse Forums DIY, Home Maintenance & Repair Re: Floating timber bubble 2Jan 10, 2010 7:14 pm Hi rolandd, What type of floating timber floors do you have? Are they a real timber laminate, or simply a faux wood finish? If they are the latter then I'm not aware of anything you can do to rectify the bubble... Essentially the spilt water has caused the wood to expand below the finished surface resulting in the bubble effect. If your boards are a real timber laminate however, then you could have the section re-finished. Hope this helps and good luck!! Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6146 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3003 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 397 |
