Browse Forums DIY, Home Maintenance & Repair 1 Jan 01, 2010 9:50 pm hi fellas does anyone knows how much does electrician charge for getting two new power points. i live in quakers hill area, des anyone have any suggestions
Re: Electrical power point installation 2Jan 01, 2010 9:59 pm Definitely shop around with this one. We had quotes from 2 different people, we needed 3 installed, along with a new circuit and some safety switches. We found the cheapest was $390, the most expensive was $800. The electrician at $390 actually made the time on the day he quoted to do the job, the other at $800 was needing 3 week lead time. I'm still amazed at the price differences and the time frames. Each point is about $30, plus cable run, plus labour / call out. If you can, try and get them as close to the current points as possible as this will mean easier install (power points are piggybacked off one another) - that is, unless you only have one circuit, or the circuits in place are already overloaded. Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9241 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6520 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14221 |
