Maintaining garage roller doors
We'd love some information on maintaining these roller doors, including suggestions on how to get them to move more freely, as we'd like to install motors/remotes in the next few months. I think the quickest fix would be total replacement, but unfortunately that's going to be too expensive just now.
Thank you,
lonnie
Good luck
You are certainly going the dearest route, fitting motors to the current doors then replacing them later.
dirkadirk, I guess what I'm asking is what would the roller door company do to free up the movement of the doors, just to see if we could do it ourselves instead.
Sorry Arfur, I wasn't very clear - we're trying to work out if we can somehow fix the doors so that we don't have to buy new ones down the track. I think buying new doors would be the easiest thing to do but as you said it will be expensive. The remotes/motors are on our wish list, but that's a later priority.
Our approximately fifteen year old rollerdoor just broke down.
Is yours a B&D? There's maintenance instructions on their website.
Just a general comment on lubricants, best not to use them unless you have ascertained that they are right for the job. Hubby kept putting stuff in the keyhole and when the locksmith came out he said that had just made things worse. Dad kept putting stuff on the sliding door and when the repairman came out he said no amount of stuff was going to keep it running smoothly when what it really needed was some new ballbearings. Window guy during three month maintenance period put stuff on sticky window and when I made him have a proper look it turned out something was warped in the frame. So as you can see I'm not a fan of the spray lubricant now and ask questions later school of maintenance.
We'll try the metho or turps on the tracks and see how that goes.
Cheers.
We're in the apparently 80% of people who don't do maintenance
Kaytee, I was wondering about silicone spray, but didn't know if that could be used on the tracks or not
Lonnie,
It could be that the rubbing strips on each side of the door (normally white in colour and runs vertically on both the front & back of the door inside the tracks) have become ineffective due to build up of dirt and grime. If a company was called they would probably change these strips first, clean the tracks thoroughly (removing all traces of grease/oil/dirt) then reassemble the door. Maybe make minor adjustment to the door mechanism either side so it runs square to the frame.
Not sure if the big stores carry these spares though, if you need to change the rubbing strips that is.
Hope this helps you make a decision
Dirk
im not guilty of doing no maintenance, but after reading through some of this stuff am probably doing it all wrong...
In saying that we now have to replace ours as the damn rope has come off.
Dirk, we'll look at getting the rubbing strips replaced in the next few months. Thanks for your advice.
My 'rubbing strips' started fraying and falling to bits. I had Gliderol call and was told NO door manufacturer replaces them as it would cost more than a new door door. Apparently the door has to be removed, packed up to avoid scratching, taken back to the factory, worked on, re-packed, delivered then re-installed. So I had a new motorised door installed for under $1300
A friend some years ago backed out his car before the auto roller door was raised enough and damaged the lower panel -- same story it was easier (and cheaper) to replace the entire door rather than repair one panel.
(I wonder what happens to the old doors when they are replaced?
Quote:
(I wonder what happens to the old doors when they are replaced? )
Being mostly aluminium they end up in a scrap metal yard
3
It's a classic case of aesthetics subjugating function where style takes precedence over practicality.
21/04/2024
2
I have motorised roller blinds in my house. I motorised all the blinds I use a lot and the ones that don’t get used too often I didn’t. I went through Motorise My…
