Browse Forums DIY, Home Maintenance & Repair Re: Gutters overflowing 21Dec 26, 2012 8:39 pm The first thing to check with an overflowing water tank is the mesh on the tank's overflow outlet as these can gum up from the fine organic particulate that floats for several days on the water surface. It can be difficult with some tanks to reach the mesh from the top inlet and this task is rarely considered when the tank is optioned. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gutters overflowing 22Dec 27, 2012 7:37 am I think lisanne has the most practical answer, drilling additional overflows is cheap and I would not worry about gutters corroding. Spacing of downpipes at max 12M is important but don't overlook valleys (down pipe or an overflow should be within 1.2M of the valley). Valleys are concentrated points of water discharge and a frequent cause of overflow and facia rot. Beware of downpipes discharging into garden: possible foundation destabilisation and increased termite risk from dampness. I have used surface tension leaf guard guttering when building school fire refuges in the Dandenongs ( Olinda PS, The Patch PS Belgrave South PS and Panton Hill PS), and it is excellent. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Gutters overflowing 23Dec 27, 2012 1:05 pm EDITED 03/07/18 References to Leaf Safe Guttering have been deleted as the product is no longer available. Having an enclosed guttering system is my ideal as is diverting filtered roof water to either water tanks or to ground water recharge. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gutters overflowing 24Dec 27, 2012 1:54 pm Thank you saveH2O I was just trying to be helpful with practical suggestions and some common sense. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Gutters overflowing 25Dec 27, 2012 8:51 pm Many regulations are very difficult for the home owner to access due to the heavy copyright on Australian Standards and the expense of having to buy a complete AS booklet just to find one answer. EDITED 03/07/18 The 3 part National Construction Code (NCC) which comprises of the Building Code of Australia (BCA) Parts 1 & 2 and the Plumbing Code of Australia (PCA) Part3 can now be downloaded free of charge. Note that the Victorian Building Authority (VBA) has inserted a Victorian variation in the PCA under Part D1 which removes the BCA as a deemed to satisfy requirement for roof drainage installations. Only the referenced Australian Standards are permitted. All States and Territories have different variations within the PCA that covers different plumbing work and checking for applicable variations must always be a prerequisite when checking applicable regulations. Local council regulations may also apply. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gutters overflowing 26Dec 31, 2012 5:55 pm SaveH2O Many regulations are very difficult for the home owner to access due to the heavy copyright on Australian Standards and the expense of having to buy a complete AS booklet just to find one answer. So true. |
