Browse Forums DIY, Home Maintenance & Repair 1 Nov 12, 2009 8:38 pm Hi Guy's I am new to the home reno and painting scene so this question may seem silly but is important for me I am about to start painting the bathroom and want to know what sort of paint I need to use on the ceiling. I do have a gloss white paint (water based) left over from another room, is this suitable or do i need a paint dedicated for use on a bathroom ceiling. Regards, Darren Re: Painting the Bathroom Ceiling 2Nov 14, 2009 10:16 pm Hey Darren, In my limited experience there is a special 'bathroom ceiling white' for that purpose, which has anti moulding chemicals added to help reduce or stop mould. From memory they too come in different flavours such as semi gloss, high gloss etc. I got caught out once on a bathroom reno when I used flat, as there wasn't much lighting in the bathroom, so it was dark and dull. Then again if you have heaps of bright light or downlights with High Gloss you will need sunnies to enter. Humph. Quitting Time is the time between the start of your project and the never ending finish. Re: Painting the Bathroom Ceiling 3Nov 14, 2009 11:23 pm ^^ +1 Where you are coming from is where you are going to... Re: Painting the Bathroom Ceiling 4Nov 15, 2009 1:20 pm Thanks guy's I hooked into it this morning and gave the ceiling and cornices three coats. I forgot to mention that the pain i have is labelled wet area so i took a punt and used it. My aim is to have the room reflect as much natural light as possible, its a very dark bathroom at the moment. Just painting the ceiling has made a huge difference (The previous ceiling paint was a flat white and appeared to only have on coat) Next week the skytube will be fitted and willo paint the walls above the tiles and pale yellow (Apple cider it's called) Cheers Darren. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5025 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8214 |
