Browse Forums DIY, Home Maintenance & Repair 1 Nov 07, 2009 9:13 pm Hi guys, While trying to fix a bracket for curtain rod i accidently made a 1.5" hole in my plasterboard wall . I need to know how to fix it so that i can install that bracket again. I can not change the location as other end bracked has been installed and screwed in. Please advice what can i do ? Cheers!! Re: Plasterboard wall hole ?? 2Nov 09, 2009 8:01 pm Boral have a very nice tutorial on their web site. http://www.boral.com.au/diy/?AUD=homeGa ... ggleItem=1 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7944 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4469 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2577 |
