Browse Forums DIY, Home Maintenance & Repair 1 Oct 30, 2009 12:52 pm I need some advice on how to fix and paint a wall. We've just bought a house and someone had put up cork tiles on the kitchen wall with double-sided tape. When I pulled them off, the wall peeled, exposing what looks like cardboard underneath the paint and top layer (sorry have no idea what anything is called). I'd like to patch it up and repaint. DH thinks we should cut the peeling bit back to where it holds fast, then fill with something and paint. Any tips? TIA Rachel Re: How do I fix a wall that has peeled fibreboard/plaster 2Oct 30, 2009 1:24 pm Where you are coming from is where you are going to... Re: How do I fix a wall that has peeled fibreboard/plaster 3Oct 30, 2009 1:29 pm Assuming that it is only a small area... Yes - your DH is right (... he is always right ) You can use joint compound (a few layers) and then make sure to use a primer before applying your coats of paint. Also make sure that you peal off any of the top layer gyprock "paper" that is still loose. If it's a big area, just cut out and remove the gyprock and replace with a new piece. Generally, when removing wall tiles from gyprock - the approach is to cut out the gyproeck and replace. It's easier and cleaner. Re: How do I fix a wall that has peeled fibreboard/plaster 4Oct 30, 2009 1:37 pm Where you are coming from is where you are going to... Re: How do I fix a wall that has peeled fibreboard/plaster 5Oct 30, 2009 1:55 pm Thanks so much The tiles werent actual ceramic tiles, but cork tiles stuck onto a board and then stuck up on the wall with double-sided tape (which i only realised after I'd started pulling it off). I suspect it was done buy a former tenant. I was tihnking it may actually be easier and less fiddly to replace the wall rather than patch it up. The area is about a 80x50cm but is only peeling in small bits. We will eventually be tearing the wall out but don't have the funds for a kitchen reno right now. Any ideas about what to paint a lovely 80s pinky beige coloured kitchen?? Re: How do I fix a wall that has peeled fibreboard/plaster 6Oct 30, 2009 1:57 pm Yep... something else Sorry no good with decorating Where you are coming from is where you are going to... DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8911 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5024 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5295 |
