Browse Forums DIY, Home Maintenance & Repair 1 Oct 26, 2009 4:47 pm Have brick wall back to rendered concrete all clean. Want to make sure now it is sealed as a garden is going up against it and dont want water coming in like before and bringing salt rot with it. What can I buy to apply to render to really stop all moisture coming through to interior? dingdong Re: Waterproofing Exterior Brick 2Oct 26, 2009 7:08 pm Personally I wouldn't be putting a garden bed directly up against the wall and more so if you've had problems before. Have you kept the weep holes free of any blockages? otherwise they will cause problems down the track too, with moisture being trapped and soaking every thing within the cavity. Dirk Re: Waterproofing Exterior Brick 4Oct 27, 2009 10:16 am More info needed I think. Is it going above or below the damp proof course? Slab or timber floor? Weepholes, vents or anything like that? What length? What termite treatment do you have? There are places around our house where I would feel okay about building up the garden bed, but not above the damp proof course or too close to weep holes. I've seen houses with built-in planter boxes on the exterior but to have any hope at all that it won't cause problems I think you would need to have it planned properly from the start, taking into account moisture and weight and termite protection and everything. You say you "don't want water coming in like before" so is it a repair you are doing? Is it a planter box that was part of the house design or a built up garden bed added after construction? Re: Waterproofing Exterior Brick 5Oct 27, 2009 10:30 am Hey dingdong, Look it can be done But you need to do a good job or you WILL have problems. The area that you intend to make garden bed, needs to be 'tanked' This is not getting smashed and painting the wall The total area within the garden box will need to be coated with a suitable elastomeric coating. There are heaps... but the good ones only number a few If you want some product names give me a PM with more info... .. and I can suggest a product/manufacturer available near you. Onc PS don't go getting all cleaver and stuff this can be done ( and has ) with great success. PPS Also I have repaired many garden beds 'tanking', so I know what to look for Where you are coming from is where you are going to... DIY, Home Maintenance & Repair fair question about the slope. Re soil I mean that it doesn't look like reactive clay which swells and shrinks with wetness/dryness. If the floors in your house are… 3 17594 Hi all, I am currently building through Simmonds and stuck deciding on my exterior cement roof titles and brick colours. The front and fascade of the house is a pretty… 0 2720 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8456 |
