Browse Forums DIY, Home Maintenance & Repair 1 Sep 15, 2009 7:43 pm have had some paint spills on our slate flooring pretty sure it is acrylic is very hard to get off, painting buddy said ti try soap and a soft steel wool he also said instead of laboriously doing that, and then re-sealing it ... it may be an option to paint the slate. Is this an option ? here are some pics Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ thanks in advance ! Re: Slate painting spills (pics) 2Sep 19, 2009 6:46 pm Slate is soft. Scratch it off with a scraper or small tool (ask for one at the hardware and see the looks you get ) until there is only a residue of paint then steel wool it dry turning the wool. Wipe it with a damp cloth to see if there is any more paint Remove any, the job will be better then ... reseal only the tiles you scrubed. Where you are coming from is where you are going to... Re: Slate painting spills (pics) 4Oct 20, 2009 9:53 pm or buy some citrus paint stripper, applied by brush and wiped of with clean rag will lift it easily and you can wash out the brush afterwards, has a nice orange smell to it and costs about 20 bucks ! I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3344 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 352 |
