Can anyone suggest a product we can use ourselves to fix rising damp - we have this problem in the brickwork in an old fire place.
thanks in anticipation
Jazz
Browse Forums DIY, Home Maintenance & Repair Re: Product for Rising Damp? 2Sep 13, 2009 5:22 pm Jazzie Can anyone suggest a product we can use ourselves to fix rising damp - we have this problem in the brickwork in an old fire place. thanks in anticipation Jazz How bad is it? If only superficial can be treated with a bleach solution and wipe it off If it is well entrenched in the brickwork and mortar a more drastic solution is required like removal of a line of bricks and new ones fitted with a mix of mortar and anti damp solution. Re: Product for Rising Damp? 3Sep 13, 2009 5:38 pm Kaw thats a bit drastic What about silane or a liquid membrane coating? Where you are coming from is where you are going to... Re: Product for Rising Damp? 4Sep 14, 2009 10:43 am onc_artisan Kaw thats a bit drastic What about silane or a liquid membrane coating? Oh yeah that too but it wasn't around when I did my work on this type of problem LOL! I thnik injecting may be effective although I would wait until the summer to apply or inject (assuming it is the one I know). Re: Product for Rising Damp? 5Sep 14, 2009 11:18 am We have been using Silane/siloxane for 20+ years ... we have been appling it to rammed earth/limestone buildings prior to a waterproofing admix being added to the mix... thank goodness Prior to this was used as a damp proofing system to prevent rising damp... or falling Where you are coming from is where you are going to... Re: Product for Rising Damp? 6Feb 15, 2010 4:49 pm I've heard of a product called Ardex WPM 300 water-based 2 part epoxy membrane...meant to be good at stopping hydrostatic pressure, but if it's in the walls then I think you need to replace the damp course. Neighbour has liquid siloxane injection and says its working well. I'll ask again in a year. Re: Product for Rising Damp? 8Feb 19, 2010 7:40 pm Re-plastering doesn't necessarily mean the damp problem is solved...my neighbour re-plastered his bedroom only to find 6 months later the damp had returned. If the wall was first damp proofed by the tradesman before he plastered them, then it should be OK. Otherwise the bricks themselves need treating as previously discussed in these threads. Re: Product for Rising Damp? 9Feb 19, 2010 7:48 pm I agree camelia - dealing with the cause not just the symptoms is a worry Where you are coming from is where you are going to... Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20671 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7884 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6434 |
