Browse Forums DIY, Home Maintenance & Repair 1 Aug 27, 2009 12:58 pm Hi all, the house has cedar cladding (weatherboards) down to the slab. Some concrete has been laid outside and the bottom cedar board has what appears to be some sort of flexible sealant fitted. During heavy rainfall, water comes into the kitchen area so it's fair to say the sealant isn't doing the job. Would it be correct to remove a couple of the bottom weatherboards exposing the wall frame bottom bearer and fit some flashing. Nail it to the bottom bearer with gal clouts and leave an overhang to the outside and put back the weatherboards. The problem with that is that water could still get underneath the flashing. How can it be repaired so that water can no longer pass inside. Would the concrete that has been laid outside have to be removed so the flashing can be placed in there, then new concrete laid? What to do? Re: Flashing repair at slab question. 2Aug 28, 2009 11:55 pm Sounds like the external concrete is too high and well pooling flows back into the house Flashtac under the weather board might help... But won't mean the BCofA regs Onc_artisan Where you are coming from is where you are going to... Re: Flashing repair at slab question. 3Aug 30, 2009 8:35 am Thanks for the reply, after much deliberation and head scratching I've decided to lay a single course of bricks alongside the problem area. I'll leave a gap between the brick and the cladding and mix in some bondcrete to the mortar. Apparently it only happens during very heavy rainfall so I'm thinking this will create a barrier and prevent that bit of water coming in. It's a very old cabin on a bush block, a couple of hippies renting it and the owner isn't fussed about what it's going to look like. I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10628 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10160 |
