Browse Forums DIY, Home Maintenance & Repair 1 Aug 12, 2009 3:29 pm Hey People, Just wondering if anyone has contracted out these guys and if they can please tell me what they think of the fixing process. It is cheaper than the standard restumping process however is it just as good. http://www.uretek.com.au/areas/buildings.html Re: Underpinning and re stumping 2Aug 23, 2009 9:39 pm if your stumps are rotten then under pining wont work, i have seen slabs , footings under pined but not stumps? i am renovating at the moment and had a partial re stump total of 78 concrete stumps ranging from 400mm exposure to 1.5 mtr exposure for $7000 Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Underpinning and re stumping 4Sep 05, 2009 10:46 am Borg - geogrouting will stabilize the ground beneth the stumps. Geogrouting is pumping a soil stabiliser into the ground, this resinous substance sets, and the ground becomes hard, then you can underpin the stumps. Onc_artisan Where you are coming from is where you are going to... I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9755 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19952 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10657 |
