Browse Forums DIY, Home Maintenance & Repair 1 May 22, 2007 11:20 am I'm having a bit of an issue trying to replace a washer in one of my tap fittings. I took a quick picture so you'd know what I'm talking about.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've taken the screw off, yet the handle refuses to budge! It seems as though its never been taken off in its life and all the lime scale has fused the thing together. I've used a reasonable amount of force, and I don't really want to end up breaking it by trying to force the thing off with multigrips. Any thoughts? Re: Fixing a leaking tap 2May 22, 2007 11:26 am You're heading in the right direction.
Get some lemon juice or CLR to remove the lime calcification. Pour it down the top section and let it sit for a few days till it gets loose. The handle is meant to lift straight up, and it is on a shaft with a flat section. So clear up the scale and you'll get there. Patience and gentle as it goes or yes, you could have issues. Good luck Cheers Steve Re: Fixing a leaking tap 3May 22, 2007 11:44 am A gentle tap with a hammer on the copper shaft will have the same result...
Not too much though Matt DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9564 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4860 |
