Browse Forums DIY, Home Maintenance & Repair 1 May 01, 2007 3:52 pm Hi,
Have a new wooden bifold door which I intend to stain. I was told that nail holes repaired with standard putty will be obvious after staining and is prone to discolouration over time. Someone suggested that I mix sawdust from the wood offcuts with PVA glue and fill in the holes with that. The colour match should be better and is less prone to discolouration. Anyone tried this before? I am experimenting with different sawdust at the moment, ranging from fine powder from sandpaper to larger chunks from a saw. Any tips on what works best? Not sure what to expect as I haven't done this type of thing before. Cheers, Ray. Re: Filling in nail holes with putty 2May 01, 2007 7:55 pm I did it with an old dresser I was restoring. I just found some similarly coured wood, cut some of it and mixed the swadust with wood glue and filled the nail holes. Two years later and you can only find the holes if you look really hard and know they are there. It's certainly better than wood putty. If all you can see are obstacles, you have lost sight of the goals DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8926 ask the surveyor for clarification would be the logical approach 1 20159 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31300 |
