Browse Forums DIY, Home Maintenance & Repair 1 May 25, 2009 4:57 pm Hi, I live on a sloping block (front to rear) and regularly get water build up under our house when it rains. I was wondering if anyone might be able to advise on possible drainage solutions? Would running an AG pipe at the front do the job? If so do I need to run it to a drain? Appreciate anyones advice! Re: Need advice with drainage problems 2May 25, 2009 6:20 pm You need to intercept the water before it enters the underneath area. Dig a trench in front of the slope deeper than the area where the water penetrates the building. (below footing top) You need to waterproof the area on the outside of the wall up to ground level. Ideally with a water proofing compound and then lay forticon plastic over it to a depth lower than your trench in front of the building. In the bottom of your trench lower than the area inside the building (below the top of the footings) you need to lay an ag. line (60 or 100mill, Id do 100) Fill the trench with blue metal up to about 150 from the surface, lay a agricultural cloth (weed cloth) over your trench and then fill with dirt up to a point just a little higher than the forticon plastic you laid against the brick wall. The plastic should rest against the wall from surface to footings and across the trench and under your ag pipe. with blue metal holding it in place against the wall. Have a slight fall on your ag line and connect it to Stormwater, ideally via a pit. I hope youre able to understand this....Im in a hurry at the mement and it might be a bit disjointed. Re: Need advice with drainage problems 3May 25, 2009 6:43 pm vvs mand You need to intercept the water before it enters the underneath area. Dig a trench in front of the slope deeper than the area where the water penetrates the building. (below footing top) You need to waterproof the area on the outside of the wall up to ground level. Ideally with a water proofing compound and then lay forticon plastic over it to a depth lower than your trench in front of the building. In the bottom of your trench lower than the area inside the building (below the top of the footings) you need to lay an ag. line (60 or 100mill, Id do 100) Fill the trench with blue metal up to about 150 from the surface, lay a agricultural cloth (weed cloth) over your trench and then fill with dirt up to a point just a little higher than the forticon plastic you laid against the brick wall. The plastic should rest against the wall from surface to footings and across the trench and under your ag pipe. with blue metal holding it in place against the wall. Have a slight fall on your ag line and connect it to Stormwater, ideally via a pit. I hope youre able to understand this....Im in a hurry at the mement and it might be a bit disjointed. Hmmm I have a similar situation except that it seems that some pipes are feeding into their random drain which pops up in the middle of my garden! I am guessing it may be the stormwater pipes but it just seems really random - should it not be going straight into Stormwater and not ending up on my garden in the middle of my lawn?! I attach a picture below. Will I have to do the same thing and divert this into a proper stormwater pipe? Re: Need advice with drainage problems 4May 25, 2009 6:50 pm Sometimes what youve pictured is actually a riser off a pipe that goes to an absorbtion pit. It is just another way to disperse water from an adsorbtion pit. When the pit fills or cant absorb more water, instead of the line backing up to your downpipes, it overflows onto the surface there. But it could also be a drain for a low ****** area. You need to know if your stormwater discharges into an absorbtion pit in the back yard or to easement or to the street. Re: Need advice with drainage problems 5May 25, 2009 6:57 pm vvs mand Sometimes what youve pictured is actually a riser off a pipe that goes to an absorbtion pit. It is just another way to disperse water from an adsorbtion pit. When the pit fills or cant absorb more water, instead of the line backing up to your downpipes, it overflows onto the surface there. But it could also be a drain for a low ****** area. You need to know if your stormwater discharges into an absorbtion pit in the back yard or to easement or to the street. Who is the best person to contact regarding this? A plumber? Any recommendations? (Area - North Shore Sydney) Thank you! Really appreciate it! Re: Need advice with drainage problems 6May 25, 2009 7:15 pm Yes, Im a plumber, but I dont do private work. i contract to real estate agencies I can recommend a friend, his name is Warren joel, 0414647078, hes at putney. hes as very good plumber and hes quite reasonable and fair. its relatively easy though to work ut where your stormwater runs. if the block slopes to the front, it will go to the street. look for holes in the kerb. if to easement or absorbtion pit the block will slope to the back. your council Willoughby? will be able to tell you if theres an easement line in your property. Re: Need advice with drainage problems 7May 25, 2009 8:06 pm vvs mand Yes, Im a plumber, but I dont do private work. i contract to real estate agencies I can recommend a friend, his name is Warren joel, 0414647078, hes at putney. hes as very good plumber and hes quite reasonable and fair. its relatively easy though to work ut where your stormwater runs. if the block slopes to the front, it will go to the street. look for holes in the kerb. if to easement or absorbtion pit the block will slope to the back. your council Willoughby? will be able to tell you if theres an easement line in your property. Excellent I will give him a call! Does he do free quotes or is there a service charge for him to come out and check it out? I would be looking to get a quote on how much it is to clear out the pipes on the property but mainly focused on this pipe at the moment. When is a good time to call him? Re: Need advice with drainage problems 9May 26, 2009 11:22 am vvs mand Ring him anytime. I dont think he charges for quotes, but most people will only quote on large jobs. He'll more than likely give you an estimation over the phone. He's popping by this afternoon as he was passing by anyway! Sounded very nice on the phone. *Fingers crossed* its nothing major! Re: Need advice with drainage problems 10Jun 25, 2009 6:26 pm I just worked on mine today. When they get full they overflow and cause a stream or flood in your yard. May be different for you. I just ran piping 40 feet to my ditch. ___________________ http://mail.google.com/mail/?shva=1#sea ... e3e3da2047 I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6663 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 2730 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 877 |
