Browse Forums DIY, Home Maintenance & Repair 1 May 25, 2009 2:03 pm My mansion has a red-tiled roof circa 1985 (?) and it's sort of ... breaking up! Every time I clean out the roof-gutters I find bits of tile. The broken corners of tiles seem particularly common. But the mortar seems to be cracking and loosening too. Obviously I'll need to get an expert in to have a look but I don't want to seriously think about a new roof for quite some time. Does it sound like there is solution short of replacement? Like, if it gets sprayed with that stuff they use on old roofs, will that not only keep the tiles waterproof but help them stick together? Re: Gimme the bad news, doc (ageing roof) 2May 27, 2009 8:55 pm Thanks PaintingPro. I can find out on the Net, I guess, but the bit I didn't follow was "repointing". Presumably this is not replacing tiles but repointing existing tiles? All my tiles seem to be pointing in an orderly way (none askew). Re: Gimme the bad news, doc (ageing roof) 4May 27, 2009 9:45 pm +1 mortar repointing moss can make your roof leak, tradies can make your roof leak and fix em'. be careful on your roof, it can be expensive. Maintenance of your roof is so important, it gets forgotten about until there is a problem and then often it cannot be fixed immediatly Where you are coming from is where you are going to... You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16130 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28257 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - Iām new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19134 |
