Browse Forums DIY, Home Maintenance & Repair 1 Mar 27, 2009 1:13 pm Hi, I've been a bit of a lurker here on this forum for a while, but this is my first post. The ceiling of my house is leaking, and it appears to be originating from the front balcony. What is the best thing for me to do? Is this something that a builder can fix? We'll also need to replace or repair at least part of the ceiling, which we'll do once the leak is stopped. All and any advise is appreciated. Thanks Re: Help - leaking ceiling 4Mar 27, 2009 7:42 pm Got any more details Where you are coming from is where you are going to... Re: Help - leaking ceiling 6Apr 05, 2009 11:58 pm It depends on how your balcony is built. If its concrete, tiled with a brick wall, first check that your balcony is draining correctly. There should be at least one drain hole, either as a simple hole through the brick wall with a piece of usually pvc pipe penetrating it, or a drainage outlet that is connected to the stormwater. Either way, make sure they arent blocked, alowing the water to dam up and pentrate back into the building. If all is ok there, you have to start thinking about water proofing. If you have tiles, perhaps the water is penetrating through cracks between the tiles. If its older than 10 years it may not have been waterproofed. In that case you may have to remove the tiles and waterproof it and then retile. It might be best for you to post some pics. Also, if your ceiling is open, look inside and see where the water is comming from, use a hose and see where its penetrating from. Re: Help - leaking ceiling 7Apr 08, 2009 9:35 am Where are you located? Can you either post pics on Homeone or you can email them to me directly. ***email link removed by Site Admin*** Then we can get a better understanding what your problem is and how we can help. Thanks Ben DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11986 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 |
