Browse Forums DIY, Home Maintenance & Repair Re: Crackling light switch 2Feb 18, 2009 7:13 pm Southies Yes, it crackles every time we turn it on. Then once on, the light itself flickers quite obviously. Is this dangerous ? Doubtful it's dangerous as it is insulated - but you will go through a lot of globes. replace it... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Crackling light switch 4Feb 18, 2009 8:42 pm Southies Yes, it crackles every time we turn it on. Then once on, the light itself flickers quite obviously. Is this dangerous ? If they have a dimmer, it will most likely be that, an you will need a new one.. as I had the same issue.. only if you have a dimmer that is Re: Crackling light switch 6Feb 18, 2009 10:04 pm Sounds like the wiring hasn't been terminated at the switch properly.
We had the same trouble with our toilet light (didn't crackle, but did work intermittantly) , turns out the electrical apprentice didn't wire the batten fix at the globe end well enough. Electrician was honest when he came back to fix it and said "Lucky it didn't burn your house down". Gee, thanks! Something I would be getting looked at asap, before something nasty like a spark sets something alight inside the wall cavity. Cheers. Re: Crackling light switch 7Feb 19, 2009 5:56 am Thanks everyone for your input
Dirtyard Darren you have me concerned as the house is timber & about 50 years old. Will advise the managing agent. Thanks. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Crackling light switch 8Feb 19, 2009 7:28 am Anything that creates sparking is potentially dangerous. If it is crackling then there is a bad contact and this will create a hot spot that will cause a fire.
"the fire was suspected to be started by an electrical fault" How many times do you hear that on the news? This is exactly what they are talking about.. get it replaced immediately by an electrician. cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au Re: Crackling light switch 9Feb 19, 2009 8:09 am Agree with Col Nation - it sounds dangerous, I would definitely be getting it checked by a professional, and I am surprised that ppl are advising you it isn't to be frank! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Crackling light switch 10Feb 19, 2009 9:43 am If it were me Southies, I would not use that light switch again. Plug in a lamp in the meantime and get it fixed ASAP. Re: Crackling light switch 11Feb 19, 2009 4:02 pm Actually, guys we now no longer use it, for that very reason. Have notified the agent & let's see whether she gets it repaired.
This rental has so many things wrong with it or breaking down, yet we're paying a premium for it. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Crackling light switch 12Mar 02, 2009 8:07 pm Hi Southie ive recently had the same issue with my Garage light switch. crackling... at the switch
I have a new house. Awhile ago the electrician came out over another issue he said they had installed some faulty light switches.. The switches move. I now have to get him back to look at the garage light switch and the rest of the switches in the house. Re: Crackling light switch 14Mar 02, 2009 8:52 pm I had the same problem with my house two days ago. It's potentially dangerous but I was able to fix it.
I turned off the main switch (MAIN SWITCH at the power panel outside the house), unplugged the light switch, re-seated the wires properly then put them back again. It's working fine now. Legally, you need to use Electrician to do that for you Re: Crackling light switch 15Mar 05, 2009 1:22 am Quote: Legally, you need to use Electrician to do that for you Yes you do, because should you have troubles later with an electrical fault or fire anywhere in the house be prepared for the insurance company to scrub you IF they find out you have been monkeying with the wiring or switches. Call an electrician Arfur Re: Crackling light switch 16Apr 28, 2009 11:43 am We had a switch in the bathroom that did that. A sparky came out, pulled the switch apart and put it back together. He didn't even switch off the power to do it! All good ever since. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1246 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11821 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17405 |
