Browse Forums DIY, Home Maintenance & Repair 1 Feb 06, 2009 7:35 pm Re: Crack on exterior wall 3Mar 13, 2009 6:25 pm Strange how the cracks are so straight. It looks as if these are sheets used as cladding. I would use some flexible sealer and then paint over. But I'm no expert. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Crack on exterior wall 4Mar 13, 2009 6:38 pm Casa2 Strange how the cracks are so straight. It looks as if these are sheets used as cladding. I would use some flexible sealer and then paint over. But I'm no expert. I agree... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Crack on exterior wall 5Mar 13, 2009 8:39 pm There's a special type of paint that fixes this problem. I believe it's called "Elastomeric Paint"
As the cracks appear to be following joints in the sub structure any ordinary exterior paint will continue to fail due to thermal expansion/contraction. I believe Dulux make elastomeric finishes. Re: Crack on exterior wall 6Mar 18, 2009 9:39 pm .and use a fibreglass or other scrim to brdge the gaps.
Make sure the sheeting is proply fixed before re-coating Re: Crack on exterior wall 8May 26, 2009 11:10 pm 9finances I'm just wondering why some stone/cement wall cracks.. Is it due to different weather? It can be due to moisture (in some countries it's the freezing of water which gets into the strcuture and expands as it freezes) and the heating and cooling of the stone/cement, or subsidance and the actual structure shifting could also cause this. Re: Crack on exterior wall 9May 27, 2009 8:48 pm or the substrate... does the render cover an old penetration? ie a window? Freeze/thaw can do it, also heat/cold. Thermal coefficients catches many out Topical coatings and changing substrates, make it quite difficult to avoid cracking at the old site, sometimes construction jointing or control jointing is needed to avoid future maintenance Where you are coming from is where you are going to... Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9302 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4471 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5141 |
