Browse Forums DIY, Home Maintenance & Repair Re: Rising Salt Damp - HELP 2Aug 22, 2006 8:24 am Hi Katie,
Does this help in the sense of offering a place to start? I have posted questions to this forum but rarely get replies. Not a criticism; an observation, maybe I am unlucky or my posts of little general interest. http://www.greenweb.com.au/archicentre/ ... pness.html. Andrew. Re: Rising Salt Damp - HELP 3Aug 24, 2006 8:08 am ANdrew, that link did not work.
Rising damp contains salty water because it is rising from the ground and brings the mineral salts with it. As such two things happen. First, fungus will not grow in any timbers near the dampness - ie the timber will not rot. Second, the salt crystallizes on the surface of the brickwork (usually brickwork) as a white efflorescence and you can brush it off as a white powder - taste it if you want! If neither of these factors are present ie your adjacent timber is rotting, there is mould but no salt then it is likely to be tap water leaking or rain water penetrating from somewhere. It can be treated and there are a few methods available and you are best to look in the yellow pages under rising damp. Don't compromise, go for the best chemical systems that ARE guaranteed. You will also need a builder/carpenter to remove and replace skirtings etc so that the contractor can get access to the brickwork as close as possible to the floor and to avoid ruining the external brickwork (if external walls). Hope that helps. Re: Rising Salt Damp - HELP 4Jul 11, 2007 5:09 pm Rising damp is this moisture that is coming from the ground. Most of older houses will have it. In it’s most obvious appearance is looks like a water lick, just upside down – it goes from the floor.
Check for any pilling, unstable, bubbling paint along the floor, marks that walls were repaired near the floor, rotten or wet skirtings? Go around the house and nock on the wall near the floor. If you hear the dull sound in some areas – might be a sigh of the wall damaged by a rising damp Re: Rising Salt Damp - HELP 5Jul 11, 2007 6:01 pm Hi Katieng,
What suburb are you in and what is your house constructed of - bricks or sandstone etc. Rising damp is common in Adelaide and many due to many houses not being built with damproof courses in the early days. So a bit more info or some photos and some folks here will be able to give you some - on-line advice- before you maybe call in a contractor to look at it. Andrew have not seen you post here - so will see what it is - I'd say it's just slipped through the keyboard Steve Re: Rising Salt Damp - HELP 6Jul 11, 2007 6:05 pm I wonder if the OP (original poster) will reply - 1 post only in Aug 06 Re: Rising Salt Damp - HELP 7Jul 11, 2007 9:03 pm OLP,
Mate you probably need to look at the age of the thread before reviving it.... Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8469 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 7298 3 10630 |
