Browse Forums DIY, Home Maintenance & Repair 1 Dec 21, 2008 9:22 am How can I remove this mould from these bricks?
I have wirebrushed them and that lightened the colour of the black mould but it is still in there. The bricks that are stippled are those that are mouldy. All of the flat bricks are fine. Any suggestions that dont involve a motorised hose? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am renovating a 3 bed house. I have no trades experience but I am keen to learn how renovate. I really appreciate the advice people give me here because I dont have a car so it is hard to get around trades places to talk to people. Re: How can I remove this mould from these bricks? see photo 2Dec 21, 2008 9:49 am It might sound strange but we had a lesser problem on some of the external bricks on our house last time we built. We were advised to try "exit mould" on them it worked. I guess you'd need to squirt a fair bit of the bottle on to them Could be worth a try.
We have a couple of bricks that look a bit green this time too. We'll probably try th same trick again when we get to handover. Blog http://wherethehearthis.blogspot.com/ Build https://forum.homeone.com.au/viewtopic.php?t=6634: Yard https://forum.homeone.com.au/viewtopic.php?f=19&t=27687&p=378401#p378401 Re: How can I remove this mould from these bricks? see photo 3Dec 24, 2008 6:40 pm What about a light spray with half strength bleach? Arfur I used bleach and it worked 4Dec 24, 2008 8:39 pm I used cheap household cleaner as it had the same ingredients as the 2.5xmore expensive Exit mould.
It worked very well. I sprayed it on the bricks using a trigger bottle. I didnt even scrub it and most of the black stain has dissapeared. When I buy some more bleach I will spray it again and scrub it. Should solve the problem. I am renovating a 3 bed house. I have no trades experience but I am keen to learn how renovate. I really appreciate the advice people give me here because I dont have a car so it is hard to get around trades places to talk to people. This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28161 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5835 |
