Browse Forums DIY, Home Maintenance & Repair 1 Dec 14, 2008 12:21 am Evening all !!
We are in the process of painting internal walls in a relatively old house. one of the rooms has a serious amount of bluetac on the walls, Short of manually scratching each tiny bit off is there and easy way of washing this off?? Re: Old Bluetac on walls 3Dec 14, 2008 4:04 pm Brad & Ree…I’m unaware of anything that will wash it off.
Best option would to be get as much off as you can via scratching and then sand the rest off with sandpaper, which you need to do before painting anyway. I have just done this in my bathroom, it sands off really easily donuts eucalyptus oil? I would not introduce any oil to paint work at all, not sure if this is a good thing! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Old Bluetac on walls 4Dec 14, 2008 4:07 pm use a ball of bluetack to dab at each little bit.. it will pull it off much easier than scratching every little bit off. Re: Old Bluetac on walls 5Dec 14, 2008 4:09 pm Wakeboardandy….perfect! and works really well when the tack is fairly fresh, not when its old. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Old Bluetac on walls 7Dec 14, 2008 4:26 pm Oil of any sort on paint work will make re painting very difficult, prep or not prep.
It will bleed into the existing paint and paint generally will not stick to it, therefore will peel off later. I had this problem in my daughter’s old room. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Old Bluetac on walls 8Dec 14, 2008 5:13 pm Try some sugar soap with a gentle scourer. It's worked for me before. Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7959 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3443 |
