Browse Forums DIY, Home Maintenance & Repair 1 Nov 28, 2025 2:30 pm Hi, I have a limestone wall at the front of my house. The ground level has been lowered to below the level of the lowest limestone block, as we have had a pool installed. The intent is the build a planter box to about the level where the sand is now (so midway through the bottom limestone block). I will then chemset some N12 rebar into the limestone block and attach to the mortar bed of the wall in front. The rebar will then be covered with soil plants. is this the right approach or will this not work.. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 0 50816 Old Home Restoration / Renovation Hi. Would anyone have advice on if box aircons can be installed in old queenslander with the slide up vertical windows? I want to retain the unction of the window , which… 0 583 Question about the above contract, if anyone has some insight - When is the contract deemed to be complete and no longer in force? Ordinarily it would be when the… 0 99283 |
