Browse Forums DIY, Home Maintenance & Repair 1 Sep 01, 2025 7:22 pm Hello, I’ve been looking into carport kits from hardware stores, and they seem affordable. But I keep hearing stories about council knockbacks, foundations not being strong enough, or DIY jobs ending up costing more in the long run. Has anyone here successfully built a carport from a kit? Did it end up being worth it, or would you recommend spending extra for a professional builder? Also, for those who hired a builder, how much did the process cost all up including approvals, concrete slab, and labor? Any horror stories of things that went wrong would be good to know so I can avoid them. Re: DIY Carport Kit vs Hiring a Builder 2Sep 10, 2025 12:03 pm Hello, I’ve been looking into carport kits from hardware stores, and they seem affordable. But I keep hearing stories about council knockbacks, foundations not being strong enough, or DIY jobs ending up costing more in the long run. Has anyone here successfully built a carport from a kit? Did it end up being worth it, or would you recommend spending extra for a professional builder? Also, for those who hired a builder, how much did the process cost all up including approvals, concrete slab, and labor? Any horror stories of things that went wrong would be good to know so I can avoid them. Mate, I’ve been looking into this myself recently, and honestly, those DIY kits look cheap at first but can sting you later. Council knockbacks, weak foundations, and having to redo stuff can end up costing more than just getting a pro in from the start. A mate of mine went with NO1 Carports Brisbane, and they sorted the permits, approvals, concrete slab, the works. Took a heap of stress off their plate. Are you thinking of giving the DIY route a crack, or leaning toward getting someone in to handle it? Re: DIY Carport Kit vs Hiring a Builder 3Sep 11, 2025 7:15 pm I’d agree with going the professional route having someone as you mentioned like No1 Carports handle the whole process takes a lot of stress out of it. They already know what council looks for and how to get approvals through without dramas. Plus, you end up with a carport that’s properly engineered and built to last. The hidden costs of DIY can sneak up quick. Did they give you an itemized breakdown of everything included, or was it just a flat package price? Re: DIY Carport Kit vs Hiring a Builder 4Dec 23, 2025 12:52 pm I’d agree with going the professional route having someone as you mentioned like No1 Carports handle the whole process takes a lot of stress out of it. They already know what council looks for and how to get approvals through without dramas. Plus, you end up with a carport that’s properly engineered and built to last. The hidden costs of DIY can sneak up quick. Did they give you an itemized breakdown of everything included, or was it just a flat package price? Using a professional like No1 Carports Brisbane really simplifies things and avoids surprises with approvals and compliance. When everything’s engineered and handled properly from the start, it usually saves time and money in the long run. Did their quote clearly list permits, engineering, and materials, or was it bundled into one overall price? Good on you for giving it a go! Biggest mistake I made with my DIY carport was not double-checking council setback rules, had to redo part of it because it was too close… 1 31363 Do you remember roughly how long your project with NO1 Carports took from start to finish? And did they handle all the permits, or was that something you had to sort out… 3 75890 Looking to get this narrow strip that leads into the carport concreted but worried if a stormwater pipe will be able to handle the weight of the concrete plus the weight… 0 69519 |
